RDFS
- Redmond Wa
- remodeling contractor
Can a sub panel in a condo that has a main breaker at the meter pack have a main breaker in the sub panel
Thank You
Depends on a few variables, mainly reason for trip and trip curves.If the sub panel has a smaller breaker than the main panel, the sub panel will (should) trip first.
Only for an overload. The trip curves will overlap for short circuits and ground faults. For those types of faults it is likely that they both will trip.If the sub panel has a smaller breaker than the main panel, the sub panel will (should) trip first. ...
Rats! Still means a trip outside in the rain...Only for an overload. The trip curves will overlap for short circuits and ground faults. For those types of faults it is likely that they both will trip.
