The $160 PLC I had in mind was the Click from Automationdirect. I have one sitting infront of me left over from some other project. It has ethernet + RS485. 8x 24vdc input and 6x relay output.
The arduino PLC is interesting in that it would make a good replacement for bare pcb arduino in situations that dictate its use, but my application is better served with a 'real' PLC.
It’s amazing how many electronic products on the market --that you will find  almost as a good as those  you mentioned . . . “REAL” PLC.
Arduino kits and
Velleman of Germany  have all kinds of  components that will make hobbyists and DIYs  happy.
I built my
Home Theater  Surround  Sound from a Velleman Kit. I had a good run with it with the kids when I used it for the AVATAR  movie when it first came out.
The thundering effect of the sound track makes for a movie house effect. I built it with six speakers with built-in tweeters. So it has a total of twelve speakers.   Amazing.
They are nice but they are not for industrial application.
Real PLCs are robust and can take a lot of abuse so to speak. I agree with the other poster.
Back to electrical panels with integrated PLC unit.
The panel can be assembled with all relevant devices to provide/control of the power being supplied to each individual lighting circuit.
UL listed/approved relays, power supply, astronomical timers (redundant feature if desired) and photo sensing devices can be installed inside  the control panel.
Some AHJ require samples  of specific component that are installed for  custom-built units.
I know L.A. is picky about something outside industrial application. Yours would be classified as “institutional” or commercial. Where there is occupancy of certain number of people- - it raises the red flag.
There are small PLC modules that have  “burned-in chips”  that can be
programmed to perform a fixed operational routine.
A small unit--the size of a  shoe box is made by Hitachi. Hitachi Module EH-150 is a popular industrial module.  Siemens and Allen-Bradley also make their own version.
You can program this network communication module—or any protocols to do this routine and never have to make any changes again.
I’ve used a few of them  in the past for CNC (Numerically controlled machine). They come in 12 to 16 input /outputs which you can leave some unused [open] if not needed.. . . just designate them “NULL” in your ladder diagram. You can activate them as your need arises. At the time it cost $1500 a pop.
Several manufactures use BACnet,  CANbus protocol (this is a centralized system used on vehicles) and LONworks, but Hitachi, the one I’ve worked on uses MODbus+.
But you don’t have to be concerned  how they function in your application—they work behind  the scene.
This module is usually mounted outside the lighting panel with it’s own enclosure where you can see those tell-tell lights without opening the lighting panel.
The “burned-in” memory in the chip stays fixed until a
re-flashing become necessary --which  is rarely needed.  This “burned-in memory” is similar to your PC BIOS  (Basic Input/Output System) on your computer motherboard. Very little chance of getting corrupted which contributes to its robust performance.
You want  those lights to come on at night [of course]. . . so, very little is  there to worry about that will conflict with the primary intent of the design criteria.. . . or make an exception during eclipse maybe ?
You really don’t need a super complicated set-up that would mimic those dancing lights showing
Shakira--undulating on a jumbo-tron (billboard)  in the middle of Times Square.
You may have to consult MCC/Panelboard  mfg shops to determine the space inside to accommodate those relays--since those lighting panels don’t have room for extra devices.
Best.
