2 3 in EMT runs out of CT cabinet 1 Mt run is roughly two feet the other EMT run is roughly four feet which gives me a total difference of almost 5 feet between parallel conductors on load side of CT cabinet, which means each conduit run would have a b and c phase within it plus 1 neutral in each conduit run and one ground in each conduit run this is a 600 amp service, one conduit run would have for 350 's a, b, c phase plus neutral and one 1/0 ground the other conduit is the same running into a problem trying to keep conductors the same length, almost all the loads are lighting and zone fans
