flashlight
- NY, NY
- Electrician, semi-retired
Normally I use an “entrance ell” I have also heard called service LB to make turn into building from meter pan on outside to service equipment on inside. ( In this case I cant poke straight through from meter box)
Due to current situation, one supplier is closed and 2 others are out of stock. Is there any reason I cant use a rigid LB, provided it is rated for the size and number of conductors, which is 3 3/0s ?
