bernardmulherin1978
- augusta georgia
I have a house that has a sub fed panel and the ground and neutrals are tied together, now the house was built in 1958,so more than likely when the sub fed panel was put in, separating the ground and neutrals was not a requirements, or maybe its totally wrong, how can I fix it, or should I fix it, I know the correct way to do it for your effective ground fault path, its to far to re pull it with the correct amount of wires, what are my options, could I put a ground bar in and come off that to a ground rod and that work. Thanks
Sent from my SM-A205U using Tapatalk
