rswolff001
I probably already know the answer but I gotta ask anyway........client is building a skid......their customer has an existing 220vac 3-phase receptacle with a ground connection. (4-pin wall receptacle) The skid will require both 220v and 120v.....they've asked if I can use one leg and use the ground as the neutral side. I have said no, that can't (or shouldn't) be done. They indicated they've done before and it should be ok.
And the answer is?
Thanks, Bob
And the answer is?
Thanks, Bob
