Junior_EE
- New York City
Here in NYC, we have had many discussions with electrical contractors about voltage drop code requirements. It always gets interesting. The following is the latest discussion.
We have 208Y/120V 3-phase, 4-wire service. Let's say the energy code requires voltage drop for a feeder to be no greater than 2%. There is a long run where the voltage drop is considerable, i.e. greater than 2% without upsizing wiring or simlar. To help, the contractor installs a 208D-208Y transformer with 2.5% taps at the beginning of the run. If the voltage drop of the feeder without the transformer is, say 5%, is it legal to install a transformer at the beginning of the run and to adjust the taps using the design load so that the beginning of the run is a 5% higher voltage (i.e. 218.4Volts) and the end of the run sees a voltage of 208Volts? Perhaps this is legal if the drop is 5%, but what about if the drop is 7.5% or 10%? Is it still legal to boost the voltage at the beginning of the run that much?
