sparky1118
- Massachusetts
- Master Electrician
I am about to replace a 100 amp service. Now since we are currently on the 2020 code I need to replace the existing meter socket with a 109 amp meter main. Here is where it gets tricky. So it’s an underground service and the panel is on the second floor. What they originally did was used an overhead meter socket and came into the meter socket through the bottom with the line side and out the top with the load. I see why they did that. Curious if I could do the same thing with an over head meter main? Only thing I’m questioning is inside the meter socket they have that opening to one side to pass conductors through. Could I pass my line and load through the same opening? It’s not a raceway it’s just an opening
any insight would be appreciated.
Sent from my iPhone using Tapatalk Pro
any insight would be appreciated. Sent from my iPhone using Tapatalk Pro
