Thejake
- Washington
- Residential Electrician
I did some searches and didn’t find an exact answer to the question I had so I figured I’d start a thread about harmonics and interference.
Here is the problem I’m having at a clients house: 5th floor condo unit, new Bosch heat pump installed on the roof (happens to be the roof of the unit), the heat pump uses an electronic inverter. When the heat pump kicks on it causes multiple banks of lights to flicker and strobe. All the lights effected are LED bulbs on Maestro dimmers. When I bypass the dimmer the problem stops. Only issue with that is; one the customer wants the dimmers, two it is also effecting the lights in the hood and a plug in heat blanket. The heat blanket has a small digital display and won’t work. This is a 208 system. I’ve checked the voltage with the system running and it’s still 208. The other interesting thing is the owner owns 2 units (501 and 502) both had new heat pumps and both are having the same issues. I checked the heat pump connections and everything is tight. I haven’t checked the main lugs in the panel but they appear fine, wire looks slightly snug and there is now discoloration or sign of heat damage on the wire. Let me know your thoughts
