I agree, it's amazing how much draft will come through a building and out or into the receptacle cutouts.I would say draft stopping is all that is necessary and most caulks will do the job.
Roger
If not an airtight rated box (or to close a dialated foam perforation in one), acoustic sealant from the outside of the box. from the inside of the box after the fact or remodeling, a UL rated acoustic putty (QuietPutty, PuttyPads etc.) since the caulk makes a mess of the box. Avoid spray foam in a box or where cotiguous with the box’s openings as ignition temperature of the cheap brands (GreatStuff etc.) is 120 C and not UL listed. A lot of folks just seem to use latex caulk, which while not a listed method, seems just fine.Caulk around the perimeter of the box to seal between drywall and box....what is a good way to seal the knockouts inside a plastic box to keep air from passing through ?
