Can someone please help me understand closed loop power flow given the following setup:
A 225kVA transformer feeds a bus (say 13.8kV) and fed from bus are two 1MW bi-directional AC/DC power supplies that are connected together to a common 1000V DC bus on their secondary's. I am told that the 225kVA transformer is only there to make up the losses in the system and that these power supplies can be ramped up to flow 1MW worth of power in the closed loop system. I'm trying to understand how with only a 225kVA supply 1MW can flow in system with transformer only making up for losses.
The power flow as I understand it comes from transformer secondary onto 13.8kV bus then goes through 1st AC/DC converter onto common DC bus which then feeds back through 2nd AC/DC converter (converting back to AC) to the primary of the 1st converter (via common 13.8kV bus). I am told that this power can keep circulating in this closed loop fashion with the first power supply being capable of being ramped up to 1MW to circulate the 1MW in the closed loop and 225kVA transformer will only make up for losses.
Can someone help explain how with only a 225kVA input this 1MW circulating power can be generated? I'm just not seeing it for some reason.
