The fixture is prewired from the manufacturer according to OP, how is that any different than chandelier wiring?Assuming 20 feet of cord ty-rapped to the chain I would say yes. Otherwise it violates the use of flexible cord because you are using it for building wiring.
Your alternative is to replace the cord with either MC or AC. Then you can connect it directly to a box above.
-Hal
But the chain may or may not be a part of the luminaire or an accessory item included in the listing.The fixture is not a pendent. That would be a fixture supported by the cord itself. It is a cord and plug connected luminaire. See 410.62(C)(1).
-Hal
And as Jusme123 said in post 3, how is this different from a chandelier? I've never seen one chandelier wiring instruction that said to put a plug on the end.
Most that come with cords are not listed for permanent installation. What product standard has it been listed to?Here’s a conversation piece.
I have a 2 lamp LED fixture. It comes pre-wired with a flexible cord.
Light will be hung 20ft in the air off of manufactures chain.
Do I need a plug end for this?
