Does Eaton make CH breaker w/ bell alarm contact?
brantmacga
Señor Member
Georgia
Former Child
I don't see it in the load center catalog; just curious if anyone has ever seen a CH 20/1 breaker w/ bell alarm contacts? Would be the equivalent of Square D QO1202100 option.
@electrical/documents/content/pg74a01te.pdf
some time back..
the server refuses to work with the link..
It’s the “@“ in the link; forum puts HTML tags in front of it.
I found that catalog last night also, but it only shows molded case breaker options. I’ve talked to a couple of people at Eaton today; I don’t think they have an equal to Square D.
Yeh, I just preferred it be integrated into the breaker.
Some times we don't get what we want and have to take what we can get. Potentially you could replace the one pole breaker with a 2 pole breaker and use the second pole but the relay is simpler and cheaper.
So the answer is, they do not. A bell alarm contact is only offered in a Pow-R-Line compatible breaker, and only in a GFCI version.
Also, as I’m somewhat new to using Eaton branded gear, I had no idea they no longer manufactured CH panelboards.
After digging deep through their catalogs I’ve found they do have plug-on AFCI’s for Pow-R-Line; only bolt-on. Nor do they have a dual-function AFI/GFI.
I will have to stick with Square D on this one.
