BOB TINI
- PHILADELPHIA
- RETIRED ARCHITECT
CAN YOU INSTALL AN INTERIOR 200A FUSED DISCONNECT SWITCH BETWEEN 2x6 STUDS 16"O.C. ?
IF SO , IS THERE A MIN. CLEARANCE BETWEEN THE DS AND THE STUDS?
THIS IS FOR POINT OF RESIDENTIAL SERVICE ENTRY AND HELPS ELIMINATE SE CABLE OR CONDUIT BEING RUN ON THE FRONT WALL OF THE RESIDENCE SO THAT THE SE CABLE CONTINUES DOWN TO THE PANELBOARD THROUGH THE INTERIOR .
ALL OTHER WORKING SPACE CLEARANCES IN FRONT OF THE DS ARE COMPLIANT.
