Off_Grid
- California
- Electrician
Hi,
I'm trying to improve an existing situation & need some input.
Current situation: A single welder located on the ground floor, with a "permanent" welding lead strung up and knot-tied to handrails of multiple expanded metal catwalks approximately 100' up a wood fired boiler structure, to achieve "convenient access" to welding points on upper levels, by disconnecting the cable sections at the floor needed to connect a stinger whip lead. -Not great.
The project goal: Install 1" conduit up the structure, with 4 T 1.5" condolets for remote welder lead receptacle stations, and a short removable lead to the welder that can be plugged in when needed for upper level welding. a single wire will be run & daisy chained to all remote stations with a split bolt & pigtail to the receptacle inside each station.
The question I need some input on, is the wire itself. I was advised that it would be a bad idea to run welding lead in conduit in this application, though it couldn't be explained why. I have tried researching it with little result in this application. This will be used primarily for maintenance and repair work, not all day everyday service. Would it be acceptable in this application, since we already have the cable on hand, or should I run something different?
