Bill Stanis
 - Long Beach, California
I have searched the NEC and the forum without any luck.
I am wanting to combine 2 #6 insulated isolated grounds into an EMT raceway. The EMT needs to be bonded at each end with a hub. I am assuming that I can NOT bond the raceway with one of the isolated grounds because that would make it not isolated since the raceway will be strapped to other metallic supports, therefore, an equipment grounding conductor would need to either be added to the run or "Jumped" at each end to bond the raceway.
Normally I would just utilize a PVC raceway but the shop specified EMT on the final stamped set of prints.
Any information or code sections would be appreciated.
