Logisticsman
- Michigan
- Logistics
In a previous thread I had explained how I am going to be running electrical power from my residence to a detached garage that is currently under construction. Forum Users have provided excellent answers to my previous questions regarding this project and I thank them all.
I have a question concerning the clamping of a 6/3 NM-B cable that will originate from my residence's service panel, be fed through the residence's exterior brick surface, and then enter into the back of a 6x6x4 surface mounted NEMA 4 PVC enclosure. In reading NEC's Chapter 314.17 (C), it states that any nonmetallic sheathed cable entering a nonmetallic box must be clamped inside the enclosure. There is an Exception to this requirement, but it only applies if the enclosure dimensions are not larger than a nominal size of 2.25" x 4". This limitation in size means the Exception can not be applied in my project's case.
Given the information in the above paragraph, I am a bit uncertain as to the best method to clamp the incoming 6/3 NM-B cable within the PVC enclosure. I am thinking of using a cable connector inserted into the entry hole I will be creating in the enclosure. Would this satisfy the cable clamp requirement? The cable connector I am considering using would be the type as shown in the attached photo. Thank you.
