Im installing an outlet for an air compressor. My Square d slip stick says 60a breaker on #10 wire.... do I need to install a 50amp 250v single phase  receptacle or will I need to install a 30amp 250v single phase receptacle.... I think it makes more sense to install a 30 amp because that’s all the conductors are sized for, and if i installed a 50amp receptacle there potential someone down the road someone will try and plug something that pulls more than thirty amps because The breaker is upsized for inrush....what’s your guys thoughts any and all help is appreciated?!
