electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
CT cabinet and CT's carbon dated to the Proterozoic Eon/1976. I am replacing the switchboard this is feeding, so will be doing a disconnect/reconnect. I dont really want to get into replacing this CT cab. I think I will at least replace the lugs on the CT's. A modern mounting base is only $400, If I can get SCL to move the CT's to it for free or cheap I would provide the new mounting base. Last time I needed SCL to move some metering wires it was 3k, I complained and they dropped it to 2k, but still dont want to get into that. Conductors are 750 CU which can stay the same and even be reused.
