Laying electrical conduit in concrete slab without sealing.
Serenity
New User
Central Florida
Design
My contractor just ran wiring in my concrete floor to the island. He dug a shallow trench and ran the wiring through a Gray conduit. However it was not secured in with a bonding agent or concrete seal..will this be an issue..in central florida..
Your inspectors will flag it if it's a problem.
Roger
In my opinion, the concrete should be patched before the floor finish is applied.
What flooring will cover the concrete?
the trench with fill is the conduit securing agent & the inside of the conduit is considered a wet location so why seal it? Joints are required to be glued together.
The trench isn't required to be filled but then the conduit is required to be secured. If the tile guy fills it with thin set you're all good.
The trench should have been filled with concrete troweled flush with the existing slab. I don't see how it could be just left that way. Maybe some idiot thought that floor tiles will bridge it? Not in my book!
Exactamundo. Return the integrity of the surface, at least.
Ten responses, nothing from the OP to date.
Electrical contractor? General contractor? General contractor having his sub electrical contractor install the conduit in the "concrete trench".
PVC conduit?
Bonding agent? Meaning, supported, strapped, in place?
Bonding agent? The only bonding agent I can think that would be used is a liquid bonding agent that is brushed on the pre cleaned side walls and bottom of the concrete trench for bonding the patching cement material to the existing concrete.
or concrete seal..
As in fill the trench with a patching cement? Or?? If there is a general contractor involved he/she may be handling that.
I think we gave the OP enough to think about.
Roger
