I_am_STILL_learning
- South Carolina
- Electrician
I have been told that the difference between a 15A 125V receptacle and a 20A 125V receptacle is only the way that the prongs are laid out. Thus, more than one 15A receptacle can be used on a 20A circuit.
So, what about 15A switches? Is it a violation to use a 15A switch on a 20A circuit?
Also, I was thinking about using a SPDT switch for lighting. The smaller switches are rated for 6A or 10A. The regular toggle switch is more expensive. Thus, I would like to know if I need to spend the extra money to match the Amps or if I could get away with a smaller amperage switch. The load is one closet light.
Thank you for your help.
