Coppersmith
- Tampa, FL, USA
- Electrical Contractor
Yesterday I repaired a service mast (riser if you prefer). Something, possibly a tree branch, must have fallen on the service drop. The mast was tilted over. The meter hub screws had sheared off and the hub was resting on the conductors. All the straps had ripped out of the wall. And the mast was slightly, but noticeably, bent.
In order to keep the price reasonable, I reused the same mast. I couldn't find any NEC reason that I could not use the mast. When the repair was completed, the mast still had a small, but noticeable, bend. It passed inspection even though the inspector said something about the bend. The power company hooked it back up.
So my question is, is there an NEC reason I missed? Just curious for next time.
