Jimmy7
- Boston, MA
- Electrician
I haven't wired a pool in years, so I was hoping the forum could tell me if going down the right path. The pool I have to wire is an inground pool with steel walls with a vinyl liner located in a single family residence. This weekend I need to bond the walls so they can backfill. I believe according to 680.26 I need to bond the pool walls in at least four points. I was going to bond with a #8 solid copper using lugs that are rated for direct burial. I was also thinking of bonding in more than four spots and leaving the #8 long enough so I could hit the wire mesh for the pool decking and equipment once they're installed. I believe years ago you would need to bring the #8 back to the panel, but you don't have to do that anymore, correct? Thank you!
