Solarsince05
New User
- san diego
- Field Operations Manager
Good Morning Solar Pros,
I am working on standardizing our new homes process across the board and one point I am trying to simplify for our teams is the electrical rough-in portion. Currently we are using all Enphase, running 10/2 from the j-box just below our array to the combiner and 10/3 from combiner to the main service. Also with that romex run is a seperate ground wire typically #8 stranded (sometimes bare if we let the rookie stock the truck), that we staple alongside the NM-B. After looking at cost vs labor, I had the thought to upsize the Romex to 8/2 and 8/3 so we could avoid having to run a separate ground wire. The issue I am running in to is that everything over #10 NM-B starts to downsize the ground. IE: 8/3 has a #10 ground.
I've called a few of our outside suppliers and Southwire directly. After getting kicked around between quite a few different people that had no idea what I was asking I decided to continue my search here. Does anyone make a #8 NM-B type wire that has the same size ground? Alternatively is there a better way that I have not thought of?
Thanks in advance.
Thanks in advance.
