Fire pump disconnecting means
Had an issue with an Inspector come up on a Rated Fire Pump Controller fed from a pad mount utility transformer. He claimed due to 2017 code change we have to have a non-fusible disconnecting means by the pad mount location in addition to the controller located on the exterior wall of the facility. This is an existing hospital and there is a gen feed going into the controller as well. I can't find in the code where this requirement is listed, does anybody know what he's alluding to?
Most likely his very own, personal, shirt-pocket rule.
Yes I would like to see what section the AHJ is citing.
Please see the link to the fire pump article I posted in this topic.
Is the controller in the same room as the fire pump?
