 - Bremerton, Washington
 - Master Electrician
I have 5 each,  8 ft 2 lamp T-12s  I want to convert to T8 or LED. My labor is free, its for a kids play room, so breakage would be a concern. Cost is as always an issue
Convert to T-8 I can leave the housing in place and get an EPCO retrofit kit, 14050, that converts the 8 ft to 2 ft lamps, I would need new ballast covers, plus new lamps, ballast cover is $10.00 each, retrofit kit is $15, ballast $20.00, or $55.00
The retro fit kit has shunted sockets, will those work with a new T-8 ballast and T-8 lamps?
Convert to LED EPCO Retrofit Kit 14050, new ballast covers, plus LED lamps, use direct wire LED lamps, remove the ballast, what type of LED lamp?
$15 kit, 2 covers, $20, lamps $48.00, or about $85.00
A new 2 lamp 4ft LED luminare is $44.98 at a big box, to replace the 5 8 footers, it would be $440.
A new 8 ft 4 lamp strip is $39.98, lamps are $2.00 each or $48.00 complete, x 5 = $240
4 ft new T-8 wrap $32.98
4 ft new LED wrap $90.00
LED lamps are about $12
McGill protecto sleeve $5.00 for 4 ft
I am thinking a new 8 ft 4 ft lamp t-8 would be affordable and less expensive than a retrofit but of course the LED has much lower energy costs. I would use the McGill protecto sleeves
The advantage of the LED is no lamp breakage issues.
