wires in the jungle
olimazi
NJ
engineer
hey guys, I ran 2 sets of #12 wire in conduit.
One end I had the sets separated and taped - terminated to 2 gfci outlets.
The other end I forgot to tape and I don't know which 3 wires (black, white, green) go to which outlet.
What's the easiest way to identify which set of wires go to which outlet?
cheers
cheers
If you have access to a meter you could ring them out and check continuity between the wires. Bug one end of the wires by two together on the end you know which ones they are. And go back to the separated ends and ring them out with the meter until you have the whole circuit identified.
Just hook them up and then turn it on. Plug a load in one of the downstream receptacles if wired incorrectly it will trip the GFCI.
so if it trips, do I swap the hot or neutral wires?
and does it matter if the grounds are swapped?
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
If you feel this action to be in error, feel free to contact me via PM to explain. Reminder to all members, if you see a questionable post, feel free to report it by clicking "Report" at the bottom left corner of the post.
