What the ?!!!?!?!!
480sparky
Iowegia
Strolling through the local bigbox store tonight, I spied these.......... 'creatures'.
1" set - screw coupler... with a flat disc welded on one end.
So,,,, what's it for?
I'd saunter down to the paint department and buy a roll of Gorilla duct tape before I bought something like that. It's like a solution looking for a problem.
That would be a setscrew EMT cap.
I think the idea of this fitting, is to make the dead-end of your conduit run look more professional (instead of improvised) and less subject to tampering. Someone has to go get a screwdriver to remove this cap, but tape they can pick off with their fingers.
Some facilities have specs that require all conduit runs to be capped when not working on them. Maybe at one time water leaked into equipment thru an open conduit
A standard EMT setscrew fitting wouldn't help that issue. Those connectors aren't even intended to be water tight.
I used some of those once in a school building, eliminated what once was the service switchboard at back of stage in the gym. Had some now abandoned feeder raceways that entered the bottom and were embedded in the concrete floor. Figured we needed to plug those or many objects were likely to get lost down those over time. Happened to remember seeing those at a big box and figured they would work great and would look like something intended for the purpose as well plus less cost than a connector, rigid coupling and a pipe plug.
There are PVC caps available also for PVC conduits.
