rod must be on my property?
wyreman
SF CA USA
electrical contractor
all concrete here
nearest patch of dirt is on the neighbor property
question never came up fir me before
the only reason why not?
his future upgrade could use my rod
or he could snip it, not under my control
Most building/zoning codes have a maximum allowed impermeable coverage for a given lot. Don't know how you wound up with 100% cover. All I can suggest is core drill to dirt and drive a rod. Or more likely, two.
lots of apartment buildings in urban areas have no dirt showing.
Acorn? Some AHJs want the acorn below grade.
some AHJ's are kind of needy.
If only 8 foot rod then the connection would need to be below grade. If longer and 8 feet of rod is below grade the connection can be above grade. Some situations may need additional physical protection.
