I am about to do a full panel swap on a residence and would like to minimize downtime since it is being lived in. The current panel is flush mounted but the new will be surface mounted in the same location. I am considering pre-wiring the new panel with short segments of conductors (sized appropriately of course) and then utilizing a gutter to splice the existing circuits to the new panel whips.
My plan is to place the gutter @18" above the panel and then either use EMT or secure the cable to the backboard between them. The new panel is a Homeline 40/80 series with Qwik grip function so knockouts are limited on the top & bottom.
Could I use romex to pre-wire the panel and then cable clamp into the gutter if they are secured per above?
The SE is not being spliced so it would need to be kept outside of the gutter since it would not qualify as a raceway any longer correct?
Curious on thoughts
Curious on thoughts
