brother
I dont recall the exact nfpa article or if it is just an OSHA issue, but is a stop button for the controls of the loading dock platform required? I always thought they were. What we found is a loading dock that the start/go button is a momentary contact has to be held in to operate the platform, basically when you release the start button the motor stops. The issue here is that the start button had gotten stuck and the platform/motor would not stop running. The staff had to rush to the disconnect to shut it off. It was once wired with the stop button but it was bypass/ no longer part of the circuit.
Since the pushbutton was momentary , I was told that this was not required. For safety reasons I thought they were required, even if its not an 'e- stop mushroom', just for some of the reasons that happen above when the button got stuck and the motor wouldnt stop.
What NEC article says this, or is it a NFPA 79 control issue, or OSHA safety?
