So I am connecting power to 2 commercial business signs. Very simple set just 120v to a single pole switch as a disconnect for the sign (all supplied and pre wired by tbe sign company).
To make a long story short the signs arent working. I have 120v off the load side of the switch (which is obviously going to the signs) to both my neutral and my ground.
Called the owner of the sign company and he insist the sign was tested several times before being hung.
My only thoughts are a lost neutral. But if i had a lost neutral would i still read 120v from hot to neutral?? Or would the voltage change because of the lost neutral.
