Beyond the fuel difference, you're also talking about a difference in engine technology -
Spark Ignited (SI) vs. Compression Ignited (CI).
Most folks refer to these commonly as Gas and Diesel engines.
What has changed dramatically in the last 8 years or so is lower HP off-road engines have become subject to the EPA Tier 2 Gas and Tier 4 Final Diesel regulations. The key point here is the amount of emissions permitted is based upon the HP of the engine itself.
Most generators are small enough that DEF is not needed. DEF is used to reduce the NOx emitted during combustion to meet EPA allowable limits. NOx increases along with combustion temperatures and engine size. Over the road trucks have used DEF fluid for quite some time due to their large HP. The next set of vehicles affected were diesel equipped pickup trucks. When the regulations began affecting the HP ranges used in gensets, many manufacturers opted not to develop engines capable of meeting the requirements.
Diesel generators that are below 74HP (55kW mechanical x 80% generator efficiency ~ 44kW generator set) usually do not require DEF fluid and may not even need a Diesel Particulate Filter (DPF) but only a Diesel Oxidation Catalyst (DOC) which performs a similar function that the Catalytic Converter does on a gasoline engine. As an example, Kubota manufactures a few stand-by diesel units - their "GL" line - that come in 7, 11 & 14kW none of which requires DEF nor have a DOC or DPF.
Propane or Natural Gas models will require spark for combustion so these units are "gasoline" engines that have been converted to run on these other fuels in the same way forklifts have been available for years using LPG.
Now, one way manufacturers can keep costs per kW low, is to use a smaller engine running at higher RPM. Generally, the generators used in these applications come in either 2 or 4 pole arrangements. Reminding ourselves of the frequency/RPM relationship (RPM = (120 x f)/ # of poles) yields an engine RPM of either 3600 or 1800. Units are available in both speeds and both fuels/engine types in the market.
So while the
initial cost per kW may be lower with a 3600 RPM unit, one must also consider several things about the unit
life cost vs. the 1800 rpm model:
- Greater fuel consumption due to RPM;
- Increased noise levels;
- Accelerated wear and tear on engine components and the drivetrain vs. 1800 RPM units.
These factors can make the total life cost (i.e. acquisition plus operation plus maintenance costs) of the higher RPM unit greater.
Natural Gas units have an advantage in home standby applications where the home already has a supply for cooking or heating. In more remote areas, diesel or LPG would be preferred since refueling can be accomplished portably either through bulk delivery or exchanging smaller tanks.
Again, the costs to refuel would depend upon the engine RPM and should be taken into consideration when comparing models. Hopefully, the manufacturers being considered publish the fuel consumption per amount of load so a comparison can be made.
There are also some restrictions by locality on the type of fuel that may be utilized by the genset. This falls into the same category as that phrase in the NEC "or by the Authority Having Jurisdiction" so the consumer would be wise to check local regulations before purchasing a unit.
Moreover, LPG units will have additional components to allow the use of LPG vs. regular gasoline. These components are relatively reliable but do add a level of complexity above a gasoline powered engine. SI engines, by their very nature, also require additional systems and components for spark ignition which are not needed in CI engine applications. Finally, SI engines will most likely have an engine ECU but CI engines may not require an ECU to meet EPA limits unit they are above around 20hp (~12 kW genset).
So to sum up, when comparing models, I would recommend consider the following:
- Lifetime ownership costs;
- Fuel Consumption rate at comparable load;
- Wear and tear based upon engine RPM;
- Noise Levels;
- Restrictions in the local area;
- Complexity of the technology required to operate engine.
