goldstar
- New Jersey
- Electrical Contractor
I had to relocate a main lug panel at a residence under renovation yesterday. When I got there the carpenters were installing siding and needed power. So, the first thing I did was to get them temp power out of the main disconnect outside. This house also had solar panels on the roof. I shut down the disconnect for the solar power and then opened the main breaker disconnect - it was a Sq. D 200A main breaker. I know it's dangerous and I had to work on the line side LIVE. I pulled the handle down and shut the main breaker off (I thought). While I was loosening one of the the lugs on the line side, the breaker handle snapped back on. I tried several times to get the handle to stay in the off position and finally succeeded. After getting a temp power receptacle installed I was about to go inside and relocate the panel but then I said to myself "I'm not going to take a chance that the breaker may snap back on" so, I disconnected the load side SER cable inside the disconnect.
I then went inside and relocated the main lug panel after which I went outside to re-connect the SER cable. While I was tightening the lugs on the load side with my Allen wrench my left arm hit the side of the meter pan and I got a jolt. I started thinking, why am I getting hit ? Is the solar back-feeding ? No, that's not possible - the disconnect was shut off and the inside wiring was disconnected. It turned out that the main breaker NEVER shut off. Yes, God was with me yesterday and I am thankful. I would have tested the wiring in the main lug panel for voltage anyway before removing the SER cable but, I didn't want to take a chance that the switch might snap back on unexpectedly. My instincts were correct.
I'm sure we all try to be as safe as possible in our trade, but occasionally we let our guard down. Let this be a lesson to all, think about what you're doing every minute you're out there doing work, especially if you're working live - no matter what the voltage is.
