curious101
 - Atlanta, GA, USA
Hi,
I was searching for references in the NEC, but could not find answers to the situation described below.
Per owner's request for new gas station (with convenience store), the architect wants to install LED strip light fixtures on the surface of the upper window sills. There will be a drywall installed between the windows and the indoor room (continuous drywall along the perimeter wall, from floor to ceiling). The lighting fixtures would be there solely to illumine the black drywall, so from the outside it looks like there is light inside, but people can't see the inside, because there is the drywall between. That being said, there is going to be no access to the lighting fixtures, unless the dry wall gets cut; this would apply for the case if the bulbs of the lighting fixtures need to be replaced. Is this "no-access-to-light fixture" situation NEC compliant?
Thank you!
Thank you!
