LarryFine
- Henrico County, VA
- Electrical Contractor
If you can't post a picture, try to post model number and as much other info as you can
I dont have plate with me. its at the shop. very small data plate . not much to go on.Take a pic of the data plate and post it here.
plate is at shop. what i know is its a 160L frame.. lists 12.5/ 16 KW. 4/2. 400 volts +/- 10% 50hzIf you can't post a picture, try to post model number and as much other info as you can
no numbers at all. the drawing no. 1 describes Delta as low speed and yy as high speed.. but how should i make this into 12 leads.
