NEC for Generator transfer switch
bdel
New User
Pa
Student
So I'm building an auto power switch for a project. I plan to run a 15amp breaker from the main panel to a Transfer switch to a sub panel that will have a 15amp emergency circuit. This is for residential not required emergency power. The transfer switch is rated for 15amps. I will have a generator hooked to the transfer switch that will supply the sub panel. The sub panel will be supplied by the main when main power is seen. When no main power is seen the transfer switch will switch to the generator which will then supply the sub panel. My question is will this be enough isolation from the main panel? Is there a back feed issue with this design? All I find in the NEC is basically no time limit for power to come on.
Any information is a great help.
You are really out of your field here.....
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
If you feel this action to be in error, feel free to contact me via PM to explain. Reminder to all members, if you see a questionable post, feel free to report it by clicking "Report" at the bottom left corner of the post.
I am closing this thread, in accordance with the Forum Rules.If you feel this action to be in error, feel free to contact me via PM to explain. Reminder to all members, if you see a questionable post, feel free to report it by clicking "Report" at the bottom left corner of the post.
(doesn't look like you actually closed the thread)
