Replacing this old round 60 amp rated meter socket enclosure with a new 125 rated Milbank meter socket enclosure and replacing existing 100amp panel with new 100amp panel. My question is, can I reuse the what looks like a 1 1/4" threadless rigid coupling going into the bottom of the existing meter on the new meter socket enclosure I will be installing? And can I reuse the, what looks like, 1 1/4" threaded connector to screw into the 1 1/4" hub that will be coming with the new meter socket enclosure? Just trying to have the correct parts needed to avoid making several trips. Thanks in advance for any advice.
