I want to confirm something relate to series rating.
For example, in 480/277 3P system, There is upstream fuse A (200kaic), it feeds panelboard P (65Kaic fully rate), it has main breaker B and branch breaker C. The calculate fault current at panelboard P is 80kA. After I check manufacture series rate table, I found out B and C can series with fuse A up to 100kaic in the series rate table.
Question: in this case, can I say Panelboard P is 100Kaic series rate? Can branch breaker C skip main breaker B to series rate with fuse A? Is the panelboard P good at this case?
