Jerramundi
- Chicago
- Licensed Residential Electrician
We typically just loop the EGC coming out of the raceway through the lug and it's run continuously to either the neutral bus or EGC bus bar.
250.122 is for equipment grounding conductors.
Bend the EGC when it comes out of the raceway so that you know exactly where it will rest in lug, mark just outside the lug on either side with a sharpie, then take your utility knife and remove that ~1" of insulation, land it in the lug, and continue the run to the bus bar.
