- Licensed Electrician
That's true for the phone equipment but everything else on cell towers is negative ground.Not that it matters for this discussion, but the positive 48VDC "return" conductor would be grounded and the hot lead would be -48VDC.
That being said, I've seen documents describing floating DC feeds to RRUs that have separate surge/lighting protection devices on the positive and negative conductors. So it might be wise to confirm that the +48VDC return conductor is bonded to the cabinet ground bar in your situation.
