Hello, wondering what your thoughts are, 1ph cap start cap run 1/2 hp 120v
Grizzly 18” drum sander (woodworking)
Trips breaker 20 amp.
Checked caps independently, with fluke 87V and they read good. Motor winding is .6ohm. And uncoupled runs and pulls 4.6amps. Hook up belt to drum and little blower exhaust fan, minus belt for feed table, oh and motor data plate says 11.3 ish can’t remember exactly for FLA
Hooked up to drum Pulls 45-46 amps obviously not for very long.
measured voltage at 3 way splitter where plugged into 12awg extension cord voltage is 119 until start then drops and stays at 77V.
A nearby table saw only drops to 114v
When doing same check
Will be calling grizzly tomorrow just wondered if I’m missing something
Tried loosening and tightening belt tension. Everything turns by hand ok.
Also ditched extension cord and plugged into outlet directly on side of house and same shutdown scenario.
I know there are smarter guys than I with more experience, curious what y’all think
Clayton.(ps Yes I am a licensed professional) let’s get that out of the way LOL.
