Jerramundi
- Chicago
- Licensed Residential Electrician
Oh I see it now. It's 90.3 Code Arrangment
Ops sorry 90.3I was wondering if there was some overlap... but 90.4 is "Enforcement" in my 2014 Handbook.
Where do you get this from? Is it a 17-20 change? JW
Yes Communication Circuits but Low Voltage is the most commonly used term.Not to nit pick, but I'm wondering if you mean "communication circuits?"
I honestly haven't read all of 800 yetMostly because it's an atypical installation for me. So I wouldn't know if there's anything in there regarding burial depth requirements... but there are definitely SOME "low voltage" burial depth requirements in 300.5. I believe column 5? But that's only irrigation and landscape lighting.
So, would that conscious ignorance of the rest of the NEC, apply to, say, vertical clearance requirements as mentioned in 225?Yes Communication Circuits but Low Voltage is the most commonly used term.
In Chapter 8, you ignore the rest of the NEC unless there is a reference to a section. Chapter 8 are the "unthumbed pages" of the NEC
Art 225 is Branch circuits and feeders. So that doe snot apply here.So, would that conscious ignorance of the rest of the NEC, apply to, say, vertical clearance requirements as mentioned in 225?
In the case of the OP, for example, if he chose to run his circuits aerially? Even though this isn't the preferred methodology.
800.3(F) defines 840 as being about Premises Broadband Communications Systems so some of it is but not all.It is thought by many that communication circuits in this section refers only to common cartier circuits and not private data or voice circuits within a building or campus.
Sent from my Pixel 4a using Tapatalk
I briefly looked through the 800's (but not thoroughly because it's not my forte) and couldn't find anything about vertical clearance requirements minus a very short sentence about over the roof clearance.800.3(F) defines 840 as being about Premises Broadband Communications Systems so some of it is but not all.
Yes exactly.I briefly looked through the 800's (but not thoroughly because it's not my forte) and couldn't find anything about vertical clearance requirements minus a very short sentence about over the roof clearance.
