Elsiervo178
- Brookline MA
- Maintenance technician
I have a burnham boiler series 2 hydronic hot water.
There is 2 circulator pump. 3Thermostat, 2 zone valve taco.
One board inside the boiler. The other opposite side outside the boiler.
2nd floor
One supply the heat for the kitchen and living room. There is 2 zone valve taco 3 wires , 2 thermostat for this floor (2nd) . This floor is control by a switching relay DPDT. Model AR 822- Argon.
That is located on the outside part of the boiler.
I can't get the boiler to turn on.
Neither the relay will close. Neither the zone valve will open or the circulator pump running.
I replaced both thermostat kitchen and living room
Still nothing happen.
3rd floor
The other circulator pump supply hot water for the heater in the bedroom at the 3rd floor. Have not zone
valve.
3rd floor have it on thermostat. Going to the squastast board inside the boiler
This one turn the boiler on.without no problem.
When the boiler was running.
I put the zone valve on manual and apply power to the circulator pump.
Then heat was coming out to the heater on the 2nd floor.
What is wrong at the 2nd floor.
2nd floor
3rd floor
valve.
