catronics
- Nevada City, CA
Hi, guys - This is a remodel question - I do a lot of remodel! I have a very narrow space (2-gang + about 1.5") to mount three light switches. Is it ever okay to put a light switch either above or below an existing light switch? Assuming that I can open the wall and change the height of the box(es), can I split the difference and mount the two boxes, one above and one below the 48" line? I'm guessing the answer is no, but I'm just checking.
The client said absolutely no on Decora (or Decora-style) switches - what are my options? Cut away the wood on the stud and put in a 3-gang box (reinforcing the stud above and below, of course)?
The switches are next to the front door, and would control two ceiling fan/lights in a "solarium" area outside the front door.
The other side of the wall is a stone wall - this area used to be outside and was a covered parking area, then they enclosed it, with huge glass walls, and we ran a couple of lighting circuits out there. It's sort of a quasi inside/outside kind of a space. So now we have two switch lines wanting to be put somewhere. The stone wall is a big problem, so is the narrow wall space on the inside wall. - Cat Cook, Nevada City, CA
