A rancher has had issues with stock being shocked at the water tank. I was called to see what the fix was. There was 14.8 volts from the water tank to ground (with a new tank heater in the water). The stock would not drink. We drove a ground rod at the source (the shop) and that did not correct the issue. We then replaced an extension cord that was a 12 gauge cord with a 14 gauge cord and that dropped the voltage to near zero.
The rancher then purchased a new 12 gauge cord and plugged it in and the problem came back. He then put the smaller cord back in service and the voltage went back to zero. Up at the source ( a shop with a dirt floor) we tested a tub of water to ground with no extension cord to the tank heater. The voltage to ground at the shop is 14.8 volts from the water to the dirt floor. The service from the shop is an older fuse box and with a tester it shows a good ground at all the receptacles. The extension cord run from the source to the water tanks is about 75 feet.
I am at a loss other than to replace the fuse box at the shop, but it is grounded well and the extension cord gig really is baffling.
Ideas??
Ideas??
