- Tennessee NEC:2017
- Semi-Retired Electrician
I installed some LED tape lights under kitchen cabinets. These were Kichler 24V LED tape/ribbon lights. I installed a 60W LED power pack,also Kichler brand. The run was about 20' but only 10' of actual ribbon. The rating of the LEDs were 3W per foot, so I had 30W total. The instructions said not to run the lights more than 20', which I was within that. I didn't run the tape through each section of cabinets, I stopped at each section and attached wire to go through the bottom edge. The run across blank areas, such as over stove or sink, was run in the wall. To make sure I had all the connections correct I tried the lights at each break in the tape where I transitioned to wire.
The lights worked at every section until I got to the next to last one, or about 8' from the end then they quit. I first thought I had a bad connection but noticed all the lights were out so I knew it wasn't a single bad connection between points. I went back to the driver and checked the voltage. I had right at 120V in but only 1.9V DC out. So I figure the driver has failed.
My question is, would just trying small sections at a time have anything to do with the driver failing since it is rated for 60W and I was driving less that 30W at the time? At no time was the switch ever on while making connections. I only turned on the switch after connections were made to make sure they worked. So I know I didn't short anything.
