synchro
- Chicago, IL
- EE
If you do it in both directions and the distance from each side that it hangs up adds up to about the total length of the pull string, then you know the problem is localized to one place. If not then you probably have even bigger problems.No, just ran a rag through as a rabbit.
But you’re right, i need to pull a piston through. That should give me a clear answer.
Thanks !
