Hello, Met the POCO at a Two-family Dwelling unit. They want to supply 2 separate services to this Single building.
One living space above one below. The Upper space has a garage below were the current panel is.
Services and Disconnects for each will be located on oposit sides of the building. Asked the GC/Owner if there have fire wall separating the two units. have a couple questions.
1: Does 230.2(d) "Different uses" qualify for this set up. I think so.
2: If There is no fire wall. Then it is a Single building, then the only way for two service is to meet 230.2
3: If there is a fire wall, then they are just treated as separate building. As long as Unit 1 power does not cross over into unite 2 and vice verse
I could have one Underground service feeding two meters with disconnects grouped, but POCO and GC don't want that at this location ( Tight area to make that work).
