olly
- Berthoud, Colorado
- Master Electrician
I need a 4" round cut in for 2 layers of drywall. Any one know of a good one? Its just has to hold a low profile LED trim. But it needs long ears 1 1/8" of drywall.
Allied Molded. about 3-1/2". you also can cut away the inner layer.Get the one with the sheet metal strap across the back and cut the sides down with tin snips.
Or take out the factory screws and replace with 3" deck screws.Get the one with the sheet metal strap across the back and cut the sides down with tin snips.
Where have I heard that? I know.................Or take out the factory screws and replace with 3" deck screws.
I've done it both ways
You can take the "wings" off and turn them around sometimes to extend them, depending on the thickness of the material. I have also put in longer screws to make them work.
Or is there weight rating?A remodel fan box is probably a much better way to go. IIRC remodel fixture boxes are not listed for fixtures in ceilings, only walls.
IIRC the carlon round blue bombers with the three wings are rated 5 pound fixture only in a wall. Not sure if it's different for the allied molded.Or is there weight rating?
Carlon is 50 lbs for walls.IIRC the carlon round blue bombers with the three wings are rated 5 pound fixture only in a wall. Not sure if it's different for the allied molded.
Why are there two layers of rock? If this is a rated assembly a cut in box will probably not be allowed.
I won't tell . . . for a price.Still only rated for wall fixtures though.
